January 5, 201213 yr Author What vehicle do you have. I will more than likely know if it'll fit or not1999 nissan Maxima GLEOk Height - 15 1/2 incheswidth - 41 1/2 inchesDepth- 39 inchesTrunk opening width - 40 1/2 but getts bigger as it goes up as you can see in the picture. Edited January 5, 201213 yr by jcs921
January 6, 201213 yr What vehicle do you have. I will more than likely know if it'll fit or not1999 nissan Maxima GLEOk Height - 15 1/2 incheswidth - 41 1/2 inchesDepth- 39 inchesTrunk opening width - 40 1/2 but getts bigger as it goes up as you can see in the picture.I actually drive a 96 infiniti i30 and I'm pretty sure that the trunks are the same aside from you having folding rear seats (had to do some cutting in my case). The biggest encosure I could fit before I removed the torsion bars was 15.5x34x27depth. That is if you want to stay in between the rear strut towers, which I have found to help considerably wth introducing air into the cabin. If it were me I'd do the single fifteen or two twelves ported. Hope this helps! If you have any questions pm me.
January 13, 201213 yr How large of an enclosure are you able to fit in your vehicle. That's the first question to address. If you don't have the proper airspace for 2 15" drivers you'll be better off with the one 15" ICON.My trunk is huge. About 54 inches wide and about 18 inches tall. Does that help?Cargo Volume, cu. ft. 14.5Space doesnt seem like a issue so go with da Dcons. U wnt b disappointed! I'd go with 8-9cuft tuned to 31hz. U will be amazed
