I could fit 2 Dcons in a sealed enclosure so should he....
What vehicle do you have. I will more than likely know if it'll fit or not
1999 nissan Maxima GLE
Ok Height - 15 1/2 inches
width - 41 1/2 inches
Depth- 39 inches
Trunk opening width - 40 1/2 but getts bigger as it goes up as you can see in the picture.
Edited by jcs921
Depth- 39 inches
I actually drive a 96 infiniti i30 and I'm pretty sure that the trunks are the same aside from you having folding rear seats (had to do some cutting in my case). The biggest encosure I could fit before I removed the torsion bars was 15.5x34x27depth. That is if you want to stay in between the rear strut towers, which I have found to help considerably wth introducing air into the cabin. If it were me I'd do the single fifteen or two twelves ported. Hope this helps! If you have any questions pm me.
How large of an enclosure are you able to fit in your vehicle. That's the first question to address. If you don't have the proper airspace for 2 15" drivers you'll be better off with the one 15" ICON.
My trunk is huge. About 54 inches wide and about 18 inches tall. Does that help?
Cargo Volume, cu. ft. 14.5
Space doesnt seem like a issue so go with da Dcons. U wnt b disappointed! I'd go with 8-9cuft tuned to 31hz. U will be amazed :)
