Posted January 5, 201213 yr THANKS FOR SUGGESTIONS AND HELP.... IM IN PLANS FOR BUILDING A PORTED BOX FOR THESE LITTLE MONSTERS (2) SUNDOWN SA-8..... I WILL BE POWERING THEM WITH A 1500 WT. MONO AMP...... LIKE TO TUNE THEM IN RANGE 30 HZ...... NEED GOOD EXPERIENCED SUGGESTIONS ON BOX BUILD AND MEASUREMNTS PLEASE...... THESE ARE GOING IN A 2002 AVALANCHE....... I WOULD LIKE TO PUT THEM UNDER THE BACK SEAT,IF THIS IS POSSIBLE...... BUT FOR NOW IM WILLING TO BUILD BOX AND JUST PLACE IT ON THE SEAT ITSELF..... I DONT WANT TO DO THE BEHIND THE SEAT CARGO GATE THING...... I JUST ELIMATED THAT ORDEAL 2 L7 15s ...... BUT THANKS AGAIN FOR ALL/ANY SUGGESTIONS HELP AND MOST OF ALL I NEED SOME MEASUREMENTS....... IM NOT TO GOOD AT FIGURING AIR SPACE CALCALATING PORT SIZE , LENGHT, DISPLACEMENT, ECT.......
January 5, 201213 yr Turn off your caps lock.Post your max dimensions and maybe someone will help you.
January 5, 201213 yr Author Turn off your caps lock.Post your max dimensions and maybe someone will help you.sorry about the caps lock..... on the dimensions im just for now going build this enclouser to place on the back seat..... so that i can remove it when necessary...... so im pretty open on enclouser w/h/d .... like keep it under 37in width..... hight and depth are more than needed......(2) sundown sa-8 on 1500 wt. port/tune to around 30hz....... i need some suggestions on enclouser size best tuning for lows (daily)....... measurements.....
January 5, 201213 yr They will fit however a cubes box will not fit. You are going to need a few fabrication skills to work around all the odd angles under the seats.
January 5, 201213 yr Author They will fit however a cubes box will not fit. You are going to need a few fabrication skills to work around all the odd angles under the seats.yes i have fab few enclouser and this will defiently be a task.... so for now i just want to build a enclouser to place on the seat that i can remove when needed....
January 5, 201213 yr 30hz is too low i tbink. I would shoot more around 35hz.You also need 1.2 to 1.5 cft net.
January 5, 201213 yr Author 30hz is too low i tbink. I would shoot more around 35hz.You also need 1.2 to 1.5 cft net. ok thanks this is what help i need...... can you possibly suggest a enclouser size that will fit on the back seat..... and measurements, port width-lenght, ect.... your help is greatly appricared.....
January 5, 201213 yr Author Do you want slot or aeroport? well ive only built slot ports in the past.... but which do you suggest..... im defiently wanting the best possible bass and lows these sa-8 are capible of...... im open to suggestions.......
