Posted February 5, 201213 yr im making a box for 2 12 Fi BL 12's and was wondering do i need a baffle for the 12's? becuse if i baffled it would mess with the volume and tuning of the box? sooo? not sure. the port is located inbetween the 12's. anyones 2cents?
February 5, 201213 yr A baffle refers to the panel the speakers are mounted to.I believe your asking about doing a double baffle, two panels glued together?Depending on the dimensions and how you do the double baffle, yes it could reduce the net volume, and increase your tuning frequency, but you can always lengthen the port to compensate for the change.I'm not suggesting some arbitrary length, you would need to calculate for it.Posting the material thickness will help others offer advice, otherwise people will likely assume your using 3/4" mdf.
February 5, 201213 yr im making a box for 2 12 Fi BL 12's and was wondering do i need a baffle for the 12's? becuse if i baffled it would mess with the volume and tuning of the box? sooo? not sure. the port is located inbetween the 12's. anyones 2cents?Do you mean add a second baffle? I would add a second baffle it won't affect the tuning or box volume by much.
February 5, 201213 yr Couldn't he double the baffle outside without affecting volume/tuning much???Yes if he did this it would only very slightly change anything.
February 5, 201213 yr Author im using 3/4 MDF, i was thinking what shogen was suggesting. well the 12's are still new so im thinking about making single wall, then after the subs are broken in, slap on another baffle on the outside.
February 6, 201213 yr im using 3/4 MDF, i was thinking what shogen was suggesting. well the 12's are still new so im thinking about making single wall, then after the subs are broken in, slap on another baffle on the outside.Why would you wait?
