Posted February 13, 201214 yr Every site I've looked on says you can't put a double din with out modification. So if anyone has pictures of their build and how they did it that would be great. I don't want to jump into doing it and mess something up. I also don't want to have to pay someone to do something i could probably do on my own. Help!
February 13, 201214 yr Author this is the one i plan on buying. http://www.sonicelectronix.com/item_24393_Jensen-VM9324.html#tabsand please don't tell me to go buy a flip out because i've heard nothing but bad things about those
February 14, 201214 yr Some models came stock with a double din. If yours is not, it can be as simple as going to the junk yard and finding a double din bezel. The bezel is the only difference the inside of the dash is the same.
February 14, 201214 yr noob question but how do i tell if it has the double din bezel?? The opening for the radio is like twice the size lol. The only thing you have to mod is there is a little plastic piece that runs across the top of where the radio mounts that you have to cut out in order for a double din to fit.
February 14, 201214 yr Check this out. It gives you an idea of what you need for the install. If you search that forum, there should be more info on the specifics of the install.
