What head unit do you have? What are all the settings on that head unit? All of them.
  • Replies 89
  • Views 7.2k
  • You may have to have an experienced installer check out your work. You are having multiple issues that seem to go beyond your skill level. It would suck the shitter if you burnt your car to the ground
Check your ohm reading at your leads that go to your amp.
Whopps. Except on sub1 the 2 leads that go to sub 2 i put on the other vc of sub1
Look at my last post and click the external link.
Yeah i did man but thats how wired mine up i thought?
Try again yours is wrong!
Do i need to take the leads to amp and move them to the other vc?
Set your meter to ohms and read the ohms with the wires unhooked. What does it read?
ok, maybe I missed it, but what subs (brand, model, and VC) and amp are you using? It looks like you're running parallel.
is it wired +to+to+to+
-to-to-to-
make sure you didnt lose a wire between coils. its very easy for one wire to come off as you try to connect another in the coil.
-to-to-to-
He has two 4ohm dvc subs.He needs a 1ohm load.for his aq750
According to my dmm my ohms is at
Flipping between 1.5 and 1.4 then its not flipping at 1.3 to 1.2
Now its flipping 1.1 and 1.2
So that sounds right
Im going to check wiring
Now its at 1.0 and. 9
Well all my wiring is in tact i cant see the problem
Edited by nousername
Each sub has to be wired exactly the same way.
than his drawing is right... as long as all positive are linked and then all negative are lined the same way... but if he loses a wire as he hooks them up he could have cancellation. I lost one on my old set up and 2 15s sounded like a single 10...
Screw it i gotta take them out to trim the carpet so they will fit
I will just rewire them up and hook to amp before i put them in box
The other thing to look for is there a volume setting for the subs on the head unit.
Yes there is. I had it +15
I quess without being there I cant help.
hm im upload some videos though i doubt they will help
