hm im upload some videos though i doubt they will help
Just follow that wiring diagram to the T.But you could have other wiring wrong. Try just one sub but set the gain low.
  • Replies 89
  • Views 7.5k
  • You may have to have an experienced installer check out your work. You are having multiple issues that seem to go beyond your skill level. It would suck the shitter if you burnt your car to the ground
Wire one sub parallel 2ohm turn the gain down to start and see if its louder.
I dont have anything to compare to as my subs arnt even getting power
ok i will go wire 1 at 2 ohms brb
Edited by nousername
Then the problem is between the hu and the amp.
Yup no power at 2 ohms
could this be caused by a bad ground possibly? My amp light turns on showing it has power but i wanted to ask anyhow
Do you have a ipod?
Well i take that back. I had bass but there were just faintly playing
Let ne fiddle with my hu
Yes sir thats what ive been using. Via auxillery
Hook a ipod direct to your amp with the proper adapter.
turn your ipod up
What adapter is that?
you can buy one at walmart. the plugin to 2 rca's to plug direct into the amp instead of your rca cables.
It is lol
I have a question... i had to buyban adapter to install my hu the gmrc01
Theres a wire on there called amp turn on. Now am i supossed to use that since my hu already comes with a remote wire
It is lol
It is lol
As long as the amp turns on dont worry about them.
Alrighty then
What about that adapter?
It will alow you to bypass the hu and hook direct to amp. best buy, walmart, target
Pretty sure i got the right one. Just a 10$ adapter that has some rca and headphone jack inputs
Yep plug that into the amp instead of your hu rca's.
Will do
Ok
Did it work?
