Well i have good news. The sub has bass! So bad rca wire?
Anything else i should do before i rewire subs and bolt them in?
  • Replies 89
  • Views 7.5k
  • You may have to have an experienced installer check out your work. You are having multiple issues that seem to go beyond your skill level. It would suck the shitter if you burnt your car to the ground
Or wrong hu setting or a bad hu.Read your manual.
Wrong headunit setting?
God i hope its not a bad headunit. Everything works <.>
But are the subs turned on?
well if i set my sub volume to +15 shouldnt they be on?
No some head units you can turn the subs off and on separetly.For each function like ipod ,cd,usb,radio.
Sub setting is on. Eq at flat
Plugged in my rca and no sound.
So eithet faulty rca or bad rca jacks on hu. Any way to test it?
I take that back. Plugged my hu rca back in and the bass is going at 2 ohms.
Time to hook it all back up!!! Pm youve been a been help. Thanks a ton!!!
Report back after im done
Buy some new rca's if thatt dont work you have a bad hu, not likey or your settings are wrong. hope you figure it out
What hu unit are you using?
Ok so i got it wired up. Now only one sub is working <.> God dangit this just cant be easy can it
its the alpine cde122
Ok so i checked the ohms
One vc reads 3.6
The other only reads 2.9-3.1
Faulty sub?
Well the 9v test passed as the cones moved
Going to buy more wire and do a better wiring job. Have a feeling some wires werent making contact
Edited by nousername
Got everything all working!!! They sound mmmm mazing!!!!
Wish i had got 12s though :D time to fine tune the amp
But boy o boy im happy!!"
