Posted March 1, 201213 yr I am going to install a sub/amp in a 2000 Accord EX this weekend. Has the factory CD player in it.Does anyone know if that will have a power turn on/powered antenna output to switch the amp on/off? I don't want to wire a switch or run it off ignition... Also, no PAC TRUNK-LOC or anything like that in the build, amp has high level inputs, and that is all it will get...Any help would be appreciated guys...-Mike
March 2, 201213 yr Tap into the "white/red" wire on the back of the factory unit, it's the switched 12v+ for the unit.http://www.modifiedlife.com/2000-honda-accord-car-stereo-wiring-diagram/Wiring Diagram.
March 2, 201213 yr I have this car, since it has the antenna in the back window there is none for the antenna, and I know on my buddys older accord the antenna would only come on when you hit radio. But like stefanhinote said, just tap into the wire he stated, or just run a switch, and also, wiring to ignition is really EASY on our cars. I have my LED halos wired to ignition.
