Posted March 8, 201213 yr Plan is to run one of these in a ported 1.0 box, My amp; Arc Audio 900.6, will put out 550 wrms bridged @ 4 ohms. How much of this power can I safely run to this sub?
March 8, 201213 yr Admin We highly recommend running around 300 watts to this sub. It is super efficient on that amount power, and really doesn't require more to get more output out of it.
March 9, 201213 yr Mark is good about responding to these, but I would wager that you can power it however you like, but warranty coverage would be sketchy above the RMS rating.
March 9, 201213 yr Power handling may increase in a sealed enclosure, but don't be afraid to use less power then your amplifier is capable of. Head room is your friend.
