Posted March 9, 201214 yr So i just put a new battery on my wifes yukon like 6 months ago...and i turn it on now and the voltage drops very rapidly..i turn on just the switch with the truck off and the voltage goes from 12.3 down to 10.6v is it the battery or is my alternator not charging it right? Its the stock 160a alt...
March 9, 201214 yr Measuring the voltage when the vehicle is idling could shed some light as to if the the alternator is doing it's job. Autozone/Checkers can also do a simple test to make sure the alt is working.You can also use a dmm to see if something is draining the battery while the vehicle is off.
March 9, 201214 yr Does her truck has any additional electrical devices? If so, how much approx how much amperage do you think they are requiring.
March 9, 201214 yr Author Just an aftermarket stereo, hid's, an my amp but i dont have any subs connected to it right now...but its still on when im driving...
March 9, 201214 yr Author I wired down some subs down to 1ohm and free aired them and i noticed my volts go from 14.1v down to 10.8v
March 9, 201214 yr If your voltage is dropping that significantly with the vehicle running and it's not loaded down excessively, then the alternator has failed.
March 9, 201214 yr Author FML!!! An how much is gm gonna charge me for a new alt? An arm an a leg man...this is bs...its a new truck man...im also gonna have to buy a new batt cuz this one is probably destroyed too
March 9, 201214 yr Author Ok so i took a drive and the volts were jumping around evrywhere...started off at 14.1v and it stopped now at 12.8...but the stock voltmeter is at 14v
March 9, 201214 yr Ok so i took a drive and the volts were jumping around evrywhere...started off at 14.1v and it stopped now at 12.8...but the stock voltmeter is at 14vWhat are you using to measure voltage?
March 9, 201214 yr Author Ok so i took a drive and the volts were jumping around evrywhere...started off at 14.1v and it stopped now at 12.8...but the stock voltmeter is at 14vWhat are you using to measure voltage?Im using my stinger voltmeter
March 9, 201214 yr Ok so i took a drive and the volts were jumping around evrywhere...started off at 14.1v and it stopped now at 12.8...but the stock voltmeter is at 14vWhat are you using to measure voltage?Im using my stinger voltmeterTry a DMM to be sure that the meter isn't messed up.
March 9, 201214 yr Author Yeah i thought about that but when the truck is off i can see the stock voltmeter go down really quick...down to 10v
March 9, 201214 yr Ok our trucks have a dumb thing. When you are cruising it drops the voltage because there is no demand. Switching on the headlight puts the vehicle into charge mode and it jumps back up to 14+, but the headlight thing doesn't work for some people. Also some people complain that these new trucks drain batteries like no ones business some people even have to go to the dealer to get the ecu reflashed. I can recommend the TahoeYukonForum just because there are many more who know more than me about these trucks. Edited March 9, 201214 yr by Fearz
March 9, 201214 yr Author Im actually a member of that forum...im just gonna remove the alt and the batt and have autozone check them..its free...and that headlight thing wont work cuz out trucks have DRL and the lights are on all the time
March 9, 201214 yr Oh yeah the DRL's are the headlights(brain fart). It's a few different tricks to get the alt to charge I just can't remember them.
March 9, 201214 yr Even if you get a HO alt it will still do the floating voltage thing when your driving. The only way I know to stop that is with a MLA module, and then you have to splice into the PCM control to get it to constantly charge at 14.9 That's why you see so many people running dual and triple brackets on these new model trucks. Edited March 9, 201214 yr by Fearz
March 9, 201214 yr Author But for my 2000w system the stock should be enough..i have the big 3 and a dutalast gold batt
March 9, 201214 yr Just for my bc2000 I'm doing big 3 and remember to ground through the electronic ground clamp to help the alt see the draw. I'm ordering a xs3400 as a secondary batt. I'm doing one run of positive and negative in 0 gauge to back where the amp is from the 3400.Now when I'm completely finished with that.I'm saving up for a dual bracket and mike singer alt then running my system completely separate from my stock charging system. Then I will be done with my electrical.
March 9, 201214 yr On the left side of the engine is the engine ground. You can see it running off the battery then it runs through this thing then is grounded to the motor.This off another guys truck off SMD(I know)That thin wire on top of the 0 gauge is the headlight ground that goes somewhere on the firewall. The 0 gauge is covering the other wire that is a little thicker then the headlight cable. The thicker wire that you can't see will be the stock engine groundOn now if you find this thing(it should be to the right of the battery just look and you should find it. If you do it currently has to grounds running through it one wire will be thicker then the other. The thicker wire will be the ground from the battery going to the engine block and you would be able to see it. The skinner wire will be the ground for the headlights. Basically the ground current is measured by the clamp and it tells the electrical system what to do.So what you is just run 0 gauge through the clamp from the negative of the batt and ground it to the engine block with the one that is already there. I'll try to get some pics tomorrow and type a description with pics. Edited March 9, 201214 yr by Fearz
March 9, 201214 yr I gonna check in the morningCool, I'll try to remember to get more pics for you because the first time I tried to find it I was completely lost.
