Posted March 13, 200422 yr what differences would i notice with a 12 inch with these differnt box sizes, 1.0CF, 1.3CF, 1.5CFwould i loose any sound quality or puchiness as i went bigger? i ask becuase i found a way to make a bit more space in my truck and as you all saw my box design in another post it ended up around 1.25CF after displacement.if you think it will make a "good" difference i can crank it up to about 1.3-1.4CF after displacement.
March 14, 200422 yr I had my box done today, and this issue was brought up. The designer insisted on having it 1.25 cubes, and I kept resisting. I specifically instructed him to have it 1.5 after displacement. So what can we expect from the differences(0.5 - 1.5 cubes)??
March 14, 200422 yr Larger box = lower F10's, higher F3's. More bottom bottom end. There won't be a huge difference in sound, but a larger sealed enclosure almost always gives you more bottom end. SQ will still be great in any box bigger than 0.4 cubes for a Magnum 12.
March 14, 200422 yr Larger box = lower F10's, higher F3's. More bottom bottom end. There won't be a huge difference in sound, but a larger sealed enclosure almost always gives you more bottom end. SQ will still be great in any box bigger than 0.4 cubes for a Magnum 12. who wait Nick, .4 cubes???????? or .4 cubes over 1.5?
March 14, 200422 yr Nick ignore the last reply, I completely understand it. My box without brackets and driver is around 1.5. I guess after displacement it would fall somewhere around 1.2-1.3. I am happy that it complies with your parameters and recommendations. =)
March 14, 200422 yr Larger box = lower F10's, higher F3's. More bottom bottom end. There won't be a huge difference in sound, but a larger sealed enclosure almost always gives you more bottom end. SQ will still be great in any box bigger than 0.4 cubes for a Magnum 12In my enclosure building experiences, I have almost always gotten a lower F3 as well as F10 as box volume has increased. Now this is only in general, but I have found when I go too large, that is when my F10 lowers and the F3 rises. But that's just my experience. Edited March 14, 200422 yr by Tirefryr
March 14, 200422 yr Author well i got it up to 1.3CF after displacement without redesigning the whole box so thats as big as it gets hehe.should be a bit of a step up from 1.25
March 14, 200422 yr Author wow i just multiplied 1.3CF by 20 and 30 percent( this is the increase most say you get with an effective polyfil job) and after displacement my box would be like 1.6-1.7CFwill polyfill really do that or am i smokin crack?
March 16, 200422 yr Yes it will effectively increase the box size (make the speaker think it's in a bigger box that is).
March 16, 200422 yr Author that just seems like a huge increase. should i tone my box down so it stays around 1.5CF with polyfil or is your recomended top box size or 1.5 on the site assuming it guna have polyfil in it?
March 16, 200422 yr No, just keep what you have and either use polyfil or don't use it. You can always take it out if you want (or vice-a-versa).
