It's been a while since I have posted on here...busy busy busy.
Anyways, I'm not a new kid on the block when it comes to car audio...I was an installer for over 6 years and play with it as much as I can now. I am requesting some insight from somebody with good experience in chasing down engine noise, because I'm at whits end!!
Setup:
2004 Audi S4
Factory deck, using the common ground preout on it (hard wired into rca's)
Alpine PXE-H650 processor
3 Sony XM2252HX amps (1 front, 1 rear, 1 sub)
Image Dynamics CX62 components front/rear
2 Polk DB12 (circa 1999, running free air in rear deck)
SO,
I think I have isolated it down to a bad capacitor in the power supply on the factory head unit:
1. When rca's (just L and R, no other rcas are connected) are disconnected from head unit to processor, noise goes away
2. Ran new power wire to head unit, straight from battery, noise still present
3. Ran new ground to trusted ground location, noise still present
4. Ran tracer grounds to everything, including processor, amps, and head unit, noise still present
5. Disconnected antennas, noise still present
6. Seperate ground to processor, noise still present
7. RCA noise suppressors (grounded or not), noise still present
8. 12V noise suppressor on the power/ground, noise still present
9. New RCA's ran down the middle of the car, noise still present
No matter what I do, I cant ditch the ghost. It's not very loud, you cant hear it with music on...but you can hear it in musical pauses or changes in songs. I dont have a spare head unit to try and trouble shoot with anymore. Only other thing I can think of is that my alternator could have some weak diodes. I dont want to start throwing money around for a new oem radio just to have the same problem. I could go buy an aftermarket, install it real quick, see if it goes away, then return it...but I would rather not unless I have to, and that still wouldnt answer my issue with it being an OEM radio problem. Could it be the fact that my signal is common ground coming out of the radio?
Thanks in advance for reading all this crap, I'm just getting desperate. Please leave all comments aside suggesting that I run my RCA's on a different side or if I ran my power with my RCA's...Thanks!
just random question, but have you tried bypassing the processor? i've heard people having issues with noise from alpine and rockford processors
Setup:
2004 Audi S4
SO,
do you have any audiocontrol equipment
Setup:
2004 Audi S4
SO,
No I dont.
Setup:
2004 Audi S4
SO,
No I dont.
im having the same problem but only when my audiocontrol dqxs is connected and when i disconnect the dqxs it goes away i did all those steps you did and nothing worked for me i didn't have this problem before i order a new audiocontrol dqxs lets see if the processor is to blame
If you have an ipod or something similar with phone plug to rca adapter and see if the signal is still clean or your still getting noise.
Yes, noise still there
Reasonable deduction would say to try a different source. However I would first hook up only one side of your patchcord to the headunit. Common grounding at the headunit may be causing the ground loop
I would also wiggle your sparkplug wires while someone listens to the system. I once had a customer with slight engine noise caused by a bad aftermarket sparkplug wire.
Currently about 1.5-2'. If I reground it, which is POTENTIALLY a better ground (next on my list) to the seatbelt, it will extend all the cables about 6-8"
Setup:
2004 Audi S4
SO,
No I dont.
I do have an Audiocontrol Epicenter...BUT it has never been hooked up in this vehicle, havent been able to find the remote.
Does it without ipod hooked up. Ipod is a direct audio connect spliced into the Sattelite audio input. Even when disconnected (seperate factory harness) the noise is still there.
I have hooked up one RCA side only as well before, no luck. This car is a coil on plug with resistor plugs.
Setup:
2004 Audi S4
SO,
No I dont.
i have it too but my issue is not with the epicenter only with the dqxs which is a digital eq / digital crossover / line driver 3 in 1
Setup:
2004 Audi S4
SO,
No I dont.
Before my Alpine PXE-H650, I hooked up a JBL GTE22 eq that I picked up off of ebay. The engine noise that that came out of it was astronaumical. I figured it was a bad eq considering it looked a little beat up, and maybe it just didnt like the signal I was giving it. It even made its OWN engine noise sound when I had the stereo on without the car running.
here this link may help you http://www.ofsoundmi.../noisecheck.htm
Thanks, thats a good link. Looks like some muting plugs will get me a little further into the trouble shooting. Can't believe I didn't remember to use them...I've been on graveyard shift for 4 months, I'm lost in life lol
no problem bro we here to help out each other
