Will 500rms make a Fi 15 bl sound good?
It depends on what you mean by "good" and what your output goals are.
500w will be adequate, depending on your expectations for output level. It will sound "better" be definition than a higher power amplifier as the decreased excursion will result in lower distortion, but it won't be as loud as a more powerful amplifier. How much output you lose depends on what level of power you are comparing to. It could range anywhere from inaudible to noticeable.
I ran a bl on less than that and it sounded great.
