Posted March 22, 201214 yr this is a really stupit question can i cause harm to my sub for tuning it to 25 hertz?
March 22, 201214 yr No, but in reality why do you want to tune so low in a vehicle? Cabin gain tends to add to the lower octaves. Most rap and hip hop style music is recorded around 30-35 hz.
March 22, 201214 yr Author bc when i was building my box i did the displacement for a 2 inch high port and that was counting the two sheets of 3/4 mdf so that only left me with a 1/2 port on the in side and the port is as long as it can go so yea its eather i pull apart the box and start over or run with it tuned to 25 hz
March 22, 201214 yr Wait.. Yeah, what kirill said did you really make a port that is 0.5inch wide and 2 inch high? :s
March 22, 201214 yr That really is a "stupit" question.stupid can't you spell.Read the first post by the OP, you'll get why he said that..
March 22, 201214 yr Author ok i fixed it now i used one 1/2 and one 3/4 mdf for the port insted of two 3/4 the ports out side size couldnt be bigger than 2 inches and with the two 3/4 peaces that left 1/2 air way which would tuned it to 25 hertz bt by me using one 3/4 and one 1/2 gives me 3/4 of air space in the port and tunes it to 32 hertz the ports inside size is 3/4 high and 10.5 wide and its 31 long
March 22, 201214 yr Author oh and im sorry i cant spell.spelling and reading gives me trouble but i can work wonders with numbers and do amazing things with my hands
March 22, 201214 yr oh and im sorry i cant spell.spelling and reading gives me trouble but i can work wonders with numbers and do amazing things with my handsNo worries man, it is the people that don't try to form sentences or intentionally misspell things that bother me.It is very hard to understand your setup, can you post pictures?
March 22, 201214 yr People misspell words all the time. If you create a thoughtful well written question. You will get a thoughtful well written answer from one of the well informed members on this forum. Again I can't understand what your problem was. I am thinking you used a 1/2" piece of wood instead of 3/4" for part of your port?
March 22, 201214 yr Author i cant get any pics at the moment because im at work but i did fix my problem. i used diffrent size mdf to make it work the top of the port is 1/2 board and the bottom is 3/4 and the center (where the air will flow) is 3/4 from top to bottom which is alot of room bc the port is 10.5 wide. the box is for two of the new sa-8v2 each sub is split from the other and are in about .6 cubic feet each tuned to 32 hertz on 600 rms watts a peace. im hoping to be in the 130 dbs with this small box but im not getting my hope up yet
March 22, 201214 yr ok i fixed it now i used one 1/2 and one 3/4 mdf for the port insted of two 3/4 the ports out side size couldnt be bigger than 2 inches and with the two 3/4 peaces that left 1/2 air way which would tuned it to 25 hertz bt by me using one 3/4 and one 1/2 gives me 3/4 of air space in the port and tunes it to 32 hertz the ports inside size is 3/4 high and 10.5 wide and its 31 longI believe his port is 3/4" x 10-1/2" x 31" long, The enclosure is .6c.f. tuned to 25 hertz.
March 22, 201213 yr this is a really stupit question can i cause harm to my sub for tuning it to 25 hertz?That really is a "stupit" question.That really is a "stupit" question.stupid can't you spell.That really is a "stupit" question.stupid can't you spell.Read the first post by the OP, you'll get why he said that.. oh and im sorry i cant spell.spelling and reading gives me trouble but i can work wonders with numbers and do amazing things with my handsTalking to S Deyoung about his spelling.Seriously you do not pay attention at all.
