March 24, 201213 yr Author have you tried checking the PPI website yep it says its 1'' but all the pics ive found on peoples doors n stuff it looks bigger than 1''. im gana make some a pillars with 2 tweets in each side a 2 dayton neos i want to get the same size neos as the tweets some what
March 24, 201213 yr 1" is probably the size of the dome.. look for the cut out diameter to find the size hole you need. it should also list the other dimensions in the manual.
March 24, 201213 yr Author 1" is probably the size of the dome.. look for the cut out diameter to find the size hole you need.it should also list the other dimensions in the manual. i cant find the manual or any other info on any site
