Posted March 26, 201214 yr I'm at my wits end trying to figure this problem. I don't know it's my amp, battery, or alternator.I have one Kicker sub amp and one Alpine 4 channel amp. The problem lies with the 4 channel amp, it keeps turning on and off. It only happens randomly. I have checked all connections and they are tight. I checked all fuses and they are good. I also have relocated the ground for the 4 channel amp but the problem still continues. The gains are not maxed at all on both amps.I have checked the voltages multiple times and there are the results :All measurements are at car idle.Both amps on : 13.79 volts - 13.81 voltsBoth amps on and AC running : 13.79 voltsBoth amps on, AC running, and rear window defroster on : 13.69 voltsBoth amps on, AC running, rear window defroster on, and wipers running : 13.69 voltsBoth amps on, AC running, rear window defroster on, wipers running, and headlights on : 12.32 voltsThere's another wrinkle in my problem. When the 4 channel amp is turning on & off, the voltage at the battery and at the 4 channel amp would fluctuate between 11.50 volts and 12.75 volts. The sub amp is always on regardless of the 4 channel amp problem.When the 4 channel amp finally turn on, stay on, and have sound output, the battery voltage would stay at a constant 14.17 volts.Is this a sign of my battery about to die ? Or signs of an alternator about to die ? Faulty voltage regulator ? 4 channel amp about to die ?I have gone to numerous Auto Zone and O'Reilly's to have my electrical system checked out and all of them said that my charging system is okay. But I would like to have your input.If it's the alternator, is it advisable to get a high output alternator ? And if I do get a high output alternator, do I need to up the fusible link amp rating ?BTW, these two amps are installed on my 300ZX with a factory 80 amp alternator.Any help would be greatly appreciated....Thanks !
March 26, 201214 yr your alt size is small.. What is required fuse for kicker and alpine amp?Sounds like low voltage is shutting off the alpine amp.Also, sounds like u need a battery in the back because relying on the frame of the car as a ground has a pretty good voltage drop from front to rear as what you are experiencing.
