Posted March 28, 201213 yr so is a second stock alt going to be as good as an ho alt??the town i live in has an auto program at college that i can get a alt from a junk yard for $$22.00 and they well clean up and run through it for me, (im waiting on a call back from them to se if they can recoil it as well)and they have a fabricating shop that for the price of materials well make a mounting bracket alsoi know that there are alot of car audio specific companys that make batteries, but would 1 everlast maxx 1N under hood(replace stock) and 4 in back(total 5) be just as good as 3 audio batteries? i can get the ELmaxx1N's for 89.99 apeice so like 450.00 for 5 batts??just woundering
March 28, 201213 yr Sounds good to me sir. Also, in my opinion, theres no such thing as "audio battery", just like theres no such thing as "audio wire". A battery is a battery, now each battery produce may be designed for a different role, but what you have listed will be great, especially with an adittional alt.
March 29, 201213 yr Author What vehicle? What kind of power?your not giving any idea of a load.94 ford explorer xltstock alt is 130a,(2) crescendo BC3500D
March 29, 201213 yr Author so heres a dumb ? how do you figure how many AH you need to use? and (2) stock 130A isnt enouph i could pick up a few more stock alts and run one on each batt would that be better?i mean for 22.00 it be simple to get a few more
March 29, 201213 yr so heres a dumb ? how do you figure how many AH you need to use? and (2) stock 130A isnt enouph i could pick up a few more stock alts and run one on each batt would that be better?i mean for 22.00 it be simple to get a few moreNow think of all the alts you would be running that's five alts if you wanted one for each batt. That just seems like a giant headache to me. I would say maybe do a dual bracket and then run two 130's and then just save up for a big 300amp as it will be better than the two stocks together. When you get into big alternator setups it becomes a headache IMO. Getting a bracket might not be a problem, diagnosing problems becomes harder. HP is affected do to alts zapping power. Finding a belt the right size and tensioning becomes a problem ect.Example 2 130= 260amps 1 250amp + 1 130amp= 380 a little cheaper route than getting a 300amp 1 300amp + 1 130amp=430 5 130amp alts= 650amps way to close to the two 300 amps to bother with the trouble IMO 2 300amp alts= 600amps Edited March 29, 201213 yr by Fearz
March 29, 201213 yr Author i understand what your saying about the multable altim going to a junkyard tomorow with my partner(he needs a sering colum) its about 20min from me they have som ambulances ill check them to see if they have any alts in them there 65.00 there but thats a 280A alt if i can find onesorry there actualy 270A Edited March 29, 201213 yr by SamuelHermon
March 29, 201213 yr i understand what your saying about the multable altim going to a junkyard tomorow with my partner(he needs a sering colum) its about 20min from me they have som ambulances ill check them to see if they have any alts in them there 65.00 there but thats a 280A alt if i can find onesorry there actualy 270AThat's good 270amps for 65 bucks. You could still go duals and have 540amps for $130 excluding bracket cost.
