April 3, 201214 yr How are you powering your toothbrush? Have you done the necessary upgrades to support that kind of toothbrush?
April 3, 201214 yr Author How are you powering your toothbrush? Have you done the necessary upgrades to support that kind of toothbrush?Yes.
April 3, 201214 yr Do you have the make/model of the toothbrush you are using sir? Each toothbrush will play a different role in each environment. We will need more detail to further assist you.
April 3, 201213 yr If you don't buy a Braun you are an idiot. Complete fucking moron in fact. They are absolutely the best. Everything else is over rated garbage.
April 3, 201213 yr Also working on a new brush. Super turbo, flossing, cleans your teeth, nose, ass, dick and everything. Taking pre-orders starting now.
April 3, 201213 yr I have some B stock Braun's I will sell you as A stock if you like.BumpAlso working on a new brush. Super turbo, flossing, cleans your teeth, nose, ass, dick and everything. Taking pre-orders starting now.BumpBumpPre-orders going fast, you better hurry before I stop taking orders for themBumpLmfao!!!
April 3, 201213 yr You need to go and try all them out at the store and see which works the best for your needs. When people ask you what you are doing get them to join in and see it their results are the same.
April 3, 201213 yr Do they clean more than rated ? I mean super-duper shiny instead of just super-shiny ?
April 3, 201213 yr Also working on a new brush. Super turbo, flossing, cleans your teeth, nose, ass, dick and everything. Taking pre-orders starting now.I want 15 and want to rep for you man!!!
April 3, 201213 yr Shirts will be available shortly. pre orders on shirts too? are they underated? if i wear a 3x should i get a 2x?? how would it fit if i order 6 of them?
