  • Replies 116
  • Views 13k
  • Yo, dawg. We heard you like pre-orders, so we put a pre-order in the pre-order so you can pre-order while you pre-order.
  • Frostedflakejake
    Frostedflakejake
    Have you tried using Torrez toothbrush calculator to figure out what toothbrush is right for you?
  • Word is, SMD is working on a plaque and gingivitis detector.
Edited by 16K
How are you powering your toothbrush? Have you done the necessary upgrades to support that kind of toothbrush?
I heard if you use the opposite end of the toothbrush you bleed less...
Do you have the make/model of the toothbrush you are using sir? Each toothbrush will play a different role in each environment. We will need more detail to further assist you.
I believe this was the pic that Tire was showing me before... He has 2 of these..
I have some B stock Braun's I will sell you as A stock if you like.
Bump
Also working on a new brush. Super turbo, flossing, cleans your teeth, nose, ass, dick and everything. Taking pre-orders starting now.
Bump
Bump
Pre-orders going fast, you better hurry before I stop taking orders for them
Bump
Lmfao!!!
You need to go and try all them out at the store and see which works the best for your needs. When people ask you what you are doing get them to join in and see it their results are the same.
I want 15 and want to rep for you man!!!
Shirts will be available shortly.
pre orders on shirts too?
are they underated? if i wear a 3x should i get a 2x??
how would it fit if i order 6 of them?
