So is there any way i could hook up something so it would be like running 2 4 ohm subs at 2 ohms? I have a single 4 ohm sub and i was wondering if you could put something with it to be able to change the resistance.. Like idek what a resistor really is but it kinda sounds about right... This is probably impossible but i wanted to ask before i recone my sub to single 2 ohm for a third of what i bought it for.. Thanks for any help. This post is really just my imagination at work... So dont criticize too hard... Just a thought
So the resistor would be taking half the power anyways?
Additionally, you can use a transformer, but one that will handle the power you are probably using will cost more than your subs and amp you already have.
This was a (semi) popular car audio item about a decade or two ago when we were only dealing with a few hundred watts...
