Posted April 24, 201213 yr Hey guys i would fist off like to say thank you for the big 3 help. i have all the parts but the wire and am getting ready to start it, The subs i will be getting will be two 10 inch FI SSDs with cooling, and amp i am not sure yet but might go with a new crescendo amp SSA now sells. also getting a second battery down the road.Well the question is do i port the box or not? I have the space to do it and i was going to do the port out of the top of the question is what do i do inside the box here is what its going to look like and it will be the same on the other side too.any help will be great
April 25, 201213 yr Author Or can i run the box all the way behind and put the ports in the middle of the box how will i do the inside of the box with the angles? any ideas?
