I'm new to both this forum and IA, but I just upgraded about a month ago from 2 Type R 12"s to 2 IA Lethal Injections, same box, same amp(~1400 rms), and was Impressed. Already planning out my next IA build...  :)
  • Replies 53
  • Views 10.4k
  • I think the answer is pretty simple. The type of people buying our products generally aren't getting it online. The internet portion of our business is a very small percentage of our overall sales.
  • liljestrand
    liljestrand
    Another reason could be that usually when people ask about which subs to get the SSA subs are usually pushed harder by forum members. That along with making quality subs will lead to there being more
  • As Corey has stated, Team Street Shakers runs Incriminator subs nearly exclusively. Definitely go on youtube and check us out. The company is run with class and the service you'll receive after the
LI's are some nice subs. You'd be even more impressed with a proper enclosure.
Current box is ~1.8 cu/ft net each sub @ 35 hz, 45 sq in port area. Daily Driven, 2001 Bonneville.. 139.7 @ 42 hz, sealed on dash, stock electrical, ~1400 watts.
I'm thinking about adding a third sub and stepping up to ~7 cu/ft tuned to 32, and more wattage + Big 3 + Battery.
I listen to mostly Rock and Metal, I built the box kind of small under the impression that it would sound better for that type of music, but I'm always up for louder!
Someday I'll quit being lazy and take some pics... Maybe. :)
You guys will see my new build later this year, I'm going to be putting a DP21 into my Explorer :)
