i need some advice on how to build a buss bar for my setup. my batteries are side by side and that is the only way i can mount them. i need the bars to stay as close to the batteries as possible (cant go by box). my battery rack is adjustable so normally they sit below the back seats and for shows i can raise them up.
well, anything you would need to build to level the terminals will create resistance then the bars on top of this thing would lose some contact too..
My advice is to use just wire but fasten it differently than what you have it now!
You do not have the actual wire terminals on the battery terminal which is not good.
Get all your wire terminals on both sides of those battery terminals and then just run a bolt through it and put a nut on it.
Edited by shizzzon
