Posted May 3, 201214 yr hey guys i have a quick question i recently built a box for two zcon 12 inch subs.it consists of a single 6 inch aero tuned to 37 hz only 9 inches depth in a enclosure 5.46 after sub displacementit seems like the sub closest to the port is unloading or sounds Blown at frequencies higher then 40 hz but the one on the left doesn't do this.. could it be the encloser is causing the sub to unload and sound distorted?i had designed a different box which would be a slot port with these specsgross volume 6.98 ft^3port volume : 1.43ft^3physical port length 20.00"port bends : noBaffle displacement : 0.19ft^3port area range 60-80in^2port area 81in^2port area per ft: 16.27in^2net volume : 4.98ft^3tuning frequency : 37.05 hz2 common port wallswoofer disp. : .38
May 3, 201214 yr It could very well be that the woofer closest to the port is unloading on the high notes making it do funky shit.How much power do you have? Do you have any current pictures of the enclosure and it's surroundings?
May 3, 201214 yr Have you inspected the sub when taken outside the box, and tried a few free air sine waves? If it sounds good to you then try switching the subs into different holes to see if the one that sounded good earlier, and vice versa.
May 3, 201214 yr Author It could very well be that the woofer closest to the port is unloading on the high notes making it do funky shit.How much power do you have? Do you have any current pictures of the enclosure and it's surroundings?i currently have two planet audio bb2400.1 strapped at 1 ohm a mechman 320 alt2 runs of 2/0 welding cable (power)2 runs of 1/0 car audio wire scosche(ground)h/u is a alpine 123 ill pull up some pics righ now just have to run out side
May 3, 201214 yr Author Have you inspected the sub when taken outside the box, and tried a few free air sine waves? If it sounds good to you then try switching the subs into different holes to see if the one that sounded good earlier, and vice versa.no i havent to tell you the truth and i really didnt think about that till i posted this to switching subs till now.. free aired them at 20 hz size wave -3 db at around 500 watts per sub with a a/c true rms meter and a a/c multi meter when i first had gotten them
May 3, 201214 yr Author i inspected the sub and the coils read out ok and here are the pictures of the current set up
May 4, 201214 yr Thats like puttin those subs in a sealed box then punching a hole in it lol Def needs more port
May 4, 201214 yr Author Thats like puttin those subs in a sealed box then punching a hole in it lolDef needs more portlol well it was tuned alot lower = more port but it only sounded good on really slowed down music i just didnt want to build a new box with out any input is the box above have enough port?
May 4, 201214 yr It needs a lot more port and your current port is to close to the trunk wall. Most likely this is causing the unloading issues.
May 4, 201214 yr Author It needs a lot more port and your current port is to close to the trunk wall. Most likely this is causing the unloading issues.got you would the sketch up above be better of a box then the current set up ?
May 4, 201214 yr Yes the box in the sketch would work a lot better. Your current box is maxing out your space in the trunk. Have you tried to turn your box around? Fire it into the cabin? If you did that and sealed it off from the trunk, I believe your results will be a ton better.
May 4, 201214 yr Thats like puttin those subs in a sealed box then punching a hole in it lolDef needs more portlol well it was tuned alot lower = more port but it only sounded good on really slowed down musici just didnt want to build a new box with out any input is the box above have enough port?I should have specified that i meant port area
May 4, 201214 yr I am using that much port area for 2 8" mids...Is there a reason you strayed so far from the recommended enclosure?
May 4, 201214 yr Author I am using that much port area for 2 8" mids...Is there a reason you strayed so far from the recommended enclosure?No sir just a new to the aero port thing read it in a couple of different places that it would sound good.. come to find out they were incorrect.. would there be enough port area from the drawing above ? Which is 81 sq*2 for 4.98 cf ?
May 4, 201214 yr That port is acting like a longer port, because of how close it comes out to the trunk, changing your tuning.Also make sure there are no air leaks whatsover.You need a lot more port for those subs, your sketched box would be much better.
May 4, 201214 yr your runny a leaky sealed box basically..odd be cause it seem like your on the right track with everything else.
May 4, 201214 yr Author That port is acting like a longer port, because of how close it comes out to the trunk, changing your tuning.Also make sure there are no air leaks whatsover.You need a lot more port for those subs, your sketched box would be much better.newbie mistake o well ill learn cool yeah i have the mdf in the car as we speak should be coming together tomorrowyour runny a leaky sealed box basically..odd be cause it seem like your on the right track with everything else. oh i never got why it plays bass balling well and everything else not so well thanks makes me feel better about putting the money in the electrical and some what in amps
May 9, 201213 yr Author Better? yessir its like night an day diffrence So I take it you have much better resultz? Thoughts so far?? i love them so far .. just bought a crescendo audio bc5500d yesterday
May 10, 201213 yr i build my own box for my 2 12" zcons. 5.9cubes gross and tuned at 26hz. gets nastyy lowww. i did a 146.7@26hz thats with 2 audioque 2200's. not strapped running 1ohm per sub.
May 10, 201213 yr Author i build my own box for my 2 12" zcons. 5.9cubes gross and tuned at 26hz. gets nastyy lowww. i did a 146.7@26hz thats with 2 audioque 2200's. not strapped running 1ohm per sub.dam man i bet it got down nasty do you have any video of them ?
May 10, 201213 yr Author heres another video of them playing that same night the new amp will be in the 16th this wensday!! i cant wait then i guess ill start a build log
