Does anyone know the factory raido wire color codes for a Lincoln navigator 2006 with navigation...
2006 Lincoln Navigator Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Violet
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/Red
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Violet/White
Right Rear Speaker Negative Wire (-): Light Blue
http://www.modifiedlife.com/2006-lincoln-navigator-car-radio-wiring-diagram/
Edited by stefanhinote
Thanks for the info......but which pin/plug is it... I have 5 in the back of the factory radio
So all the pins don't have the same color.....or is their just one pin with just these colors
you will have to look.....
in many Lincolns it will use a few pins from each harness. .
your not trying very hard so far.
I've taken it out before, just trying to get all the info that I can before I take it out again....
