Posted May 14, 201214 yr Does anyone know the factory raido wire color codes for a Lincoln navigator 2006 with navigation...
May 14, 201214 yr 2006 Lincoln Navigator Car Stereo Wiring DiagramCar Radio Battery Constant 12v+ Wire: White/VioletCar Radio Accessory Switched 12v+ Wire: Black/PinkCar Radio Ground Wire: Black/GreenCar Radio Illumination Wire: Blue/BlackCar Stereo Dimmer Wire: N/ACar Stereo Antenna Trigger Wire: Yellow/RedCar Stereo Amp Trigger Wire: BlueCar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: N/ACar Audio Front Speakers Location: N/ALeft Front Speaker Positive Wire (+): White/RedLeft Front Speaker Negative Wire (-): BrownRight Front Speaker Positive Wire (+): GreenRight Front Speaker Negative Wire (-): White/OrangeCar Audio Rear Speakers Size: N/ACar Audio Rear Speakers Location: N/ALeft Rear Speaker Positive Wire (+): Light Blue/BlackLeft Rear Speaker Negative Wire (-): YellowRight Rear Speaker Positive Wire (+): Violet/WhiteRight Rear Speaker Negative Wire (-): Light Bluehttp://www.modifiedlife.com/2006-lincoln-navigator-car-radio-wiring-diagram/ Edited May 14, 201214 yr by stefanhinote
May 14, 201214 yr Author Thanks for the info......but which pin/plug is it... I have 5 in the back of the factory radio
May 14, 201214 yr Author So all the pins don't have the same color.....or is their just one pin with just these colors
May 14, 201214 yr you will have to look..... in many Lincolns it will use a few pins from each harness. . your not trying very hard so far.
May 14, 201214 yr Author I've taken it out before, just trying to get all the info that I can before I take it out again....
