Posted May 21, 201214 yr What are the advantages or disadvantages of swapping air conditioiner for second alt ?
May 21, 201214 yr also... you'll find yourself driving alot faster with the windows down in the summer...
May 21, 201214 yr I mean... You'll just have no A/C.... if you can deal then go for it... where do you live?
May 21, 201214 yr I've thought about doing this....but I also live in oregon....we don't ever get to see the sun.
May 21, 201214 yr i live in west michigan 5 miles from lake michigan. So heat not to bad yetI'd say do it. I'm in Kalamazoo and it never gets hot enough that I need air conditioning.
May 21, 201214 yr Author Good, i thought people would say no dont do it , its not worth it.stock alt going back in for now, any suggestions on good alt that wont break the bank, maybe in the 250a to 300a range?
May 21, 201214 yr For a truck, Mechman should be fine...If you plan on literally abusing the living hell out of it beyond reason, DC Power XP line.But i must warn you.. IF you go with DC Power, it may take anywhere from 1-10weeks for delivery.
May 21, 201214 yr Author i have a mechman 270a so maybe add a second one of the same size is what ill do ...Thank you Shizzon
