Where is the Torres calculator?
  • Replies 573
  • Views 50.7k
Okay i got it but determining port area with vent mach. how do i do that? i never understood if i want it low medium or high.
Let me know if everything looks good if so building is starting tonight!
Looks instresting. Does this program say anything like you may encounter port noise if you go smaller or larger on the port?
No that is basically all you see on the screen right there.
Maybe some one can let us know. in my program it shows port noise in anything smaller than a 12" (113.04) port. When you convert yours to a round it is just over 11".
The design you have looks pretty good, but you need to make a few changes. I'd add some bracing, and change "# of common port walls" to 2 or 3. 3 = a port on the right or left side. 2 = a center port between the subs. This will change your tuning. Also your height is 24, so your port height would be 22.5 not 24. (assuming the port orientation is the standard top to bottom)
I'd use ~100 square inches of port area, a bit more if you have the room.
How do i know the displacement of bracing?
What are you using?
Torres. but never mind i got it now haha. :P give me a sec ill post the pic.
Your port is still off, it should be 23.5 H. I would change it to 23.5 X 5, and adjust the box volume to make up for the port change. What kind of power will you be running?
1500w @ 1ohm.
Not just tuning but will effect net volume as well. Especially if you use 3 common walls.
It won't let me edit on my phone. The tuning is a little off on the new Torres calculator. I let him know bit haven't heard back. See if you can download the original gray one.
Correct
I got it now i think it will work well for the most part now. haha everything is fixed as you guys said. 129.5in ^2 of port area. 11.68 cubes.
Well this is the only update I have Chop, I am pretty sure Austin has learned patience.
that was fast
Started cleaning up the wonded GCON for a rebirth!
This poor coil and spider sure did see some heat!
