June 9, 201213 yr Author hmm not sure if that would make it sound funky or not... i would let some other ppl chime in...Ok.I have money to order 2 more so just let me know guys!
June 9, 201213 yr Four 4's will be better obviously, but still not enough in my opinion.do you think he can do 2 6" on the back side.... then 1 6" on the left side and 1 6" on the right side ??
June 9, 201213 yr Depends on how hard you play them. If you are going to go balls out then an 8" driver can require a 4". From there you can do the math. If of course you NEVER turn it up then you can get away with less.Using Aero's to use an Aero port isn't a good reason. There are a time and a place for them, but that doesn't make them a logical one size fits all. For your constraints a slot will work better.
June 9, 201213 yr Author Four 4's will be better obviously, but still not enough in my opinion.I know it wont be quite enough still but could I do it like I mentioned above?@ rear firing and 1 on each side?
June 9, 201213 yr Four 4's will be better obviously, but still not enough in my opinion.do you think he can do 2 6" on the back side.... then 1 6" on the left side and 1 6" on the right side ??In my opinion the only way to do it "right" is to build a new enclosure with a slot port. I wouldn't do the ports on different planes.
June 9, 201213 yr In my opinion the only way to do it "right" is to build a new enclosure with a slot port. I wouldn't do the ports on different planes.thats what i was thinking...i wonder how 2 in the back and 2 in the front would sound lol...
June 9, 201213 yr Obviously I need to say it again, but differently.Shoehorning some aero's into your box is stupid. They have a purpose and are a good solution, but not for you or your box.
