Posted June 22, 201213 yr o.k. if you dont know my wall is to far pass the b piler.need to move it back..i also want the vent to be on top of the box.but i need help on the makein up the blue prints.cut sheets and so on.i want it to be like Jamy Spl Willoughby.if that helps
June 22, 201213 yr Have you ever gone to a restaurant, and when the waiter asked for your order, you said: "I want food."
June 22, 201213 yr Have you ever gone to a restaurant, and when the waiter asked for your order, you said: "I want food."lmao agreed...you need to explain more on what u want op... Edited June 22, 201213 yr by 16K
June 22, 201213 yr We need some pictures of what your currently working with to be able to give you better/any help.
June 22, 201213 yr Author We need some pictures of what your currently working with to be able to give you better/any help. i will up laod some pics the car is a 1999 alero 2 door
June 23, 201213 yr Many details and pics....I can help some...I would suggest to begin by removing the existing wall. This should open up all opportunity of maxim space capable of being used.
June 27, 201213 yr Author ya porkchop i am going to be ripping the wall out.i just am not ready yet soon it will be i just dont want to do it.but it needs to be done i am lookin for that 150db i know i can get it i mite also get one more kole amp and strap them..but dont know cause 6 12s 4ohm dvc =s1ohm two amps straped i can only run 2ohm then.maybe 3 subz on one and 3 on the outher one dont know yet i need a big real amp 6,600 peak and 3,600 rms.....
