I like being able to comfortably fit two golf bags & pull carts in my trunk. A free air install in the rear deck would allow me to retain the vast majority of my cavernous trunk. Having only played with the idea in a large enough wall enclosure that it may as well have been free-air, I'd like to hear experiences.
It wouldn't be a huge loss to tuck a 1.5' box in the trunk, so if infinite baffle is more trouble then it's worth, please say so.
TIA
Nick
woofer specs:
FS: 47hz
Qts 0.593
Qes 0.635
Qms 8.935
Vas 3.34L
Wrms 500
The suspension & motor control are strong.
I know what BassBoxPro says, I also know its incredibly outdated, thank you though.
I don't believe Free-air and infinite baffle are the same, so that may confuse some, but it seems you want infinite baffle.
Not sure how great that driver would be with that fs. What's the xmax and sd? Obviously IB setups aren't designed for loudness, but they generally do require a good bit of cone area.
8", 33mm one way xmax, BL in the 20. tm range.
Primarily Jazz, Dance, Hip Hop / Pop / Rap, and occasional country or classical.
need a spare?
could do a fiberglass box in the spare tire well. or perhaps you could keep the spare and create a false floor.
