January 2, 201313 yr Author Ah yes i forgot to add that the sub will be mounted on top. This box is 7.26 cubes. little on the small side but we wanted it to fit in the heep without the seats down and without the loss of visibility in the rear window. 7.26 cubes around 100^2 in of port. tuned to 32 hz. Hoping it gets nasty loud for being ran at 2ohm on the audiopipe. Im not quite sure what the amp is rated at when wired at 2 ohms... i guess we will have to find out.
