Posted August 29, 201213 yr sham wow!, so let me get this right, it uses little electricity loses no efficiency and it makes all boxs sound a like, and just buy doing what you say it will make my car sound like a pro installed it... sham wow!sign me up!
August 29, 201213 yr How did it go from 100% efficient to 1 watt from the battery makes almost 1 watt of power? Doesn't sound 100% efficient to me. If no heat is created at all then what would be the point of heat sinks?When trying to sell a lie, you need to sell it 100% not like the nearly 100% similar to the amps efficiency.
August 29, 201213 yr It is funny, but that 600D is pretty small..got me thinking lolAnd in all fairness, the language barrier is likely a large issue here as well. Edited August 29, 201213 yr by pro-rabbit
August 29, 201213 yr Author well they have to pay for the alien technology they are using to provide 100% efficiency... DUH
August 29, 201213 yr 2000 watts RMS, 4 gauge input and ground, and one 80 amp fuse. Something doesn't add up. Oh yeah, it weighs 7 lbs.
August 29, 201213 yr I have not looked into them other that video. But if what you say is true indeed it does seem "off" a bit.
August 29, 201213 yr 2000 watts RMS, 4 gauge input and ground, and one 80 amp fuse. Something doesn't add up. Oh yeah, it weighs 7 lbs.All for only $425!!! They look like Audiopipe quality with a JL price tag.
August 29, 201213 yr 2000 watts RMS, 4 gauge input and ground, and one 80 amp fuse. Something doesn't add up. Oh yeah, it weighs 7 lbs.AND they only recommend 8 gauge for the installation of the 2500.
August 29, 201213 yr Author 2000 watts RMS, 4 gauge input and ground, and one 80 amp fuse. Something doesn't add up. Oh yeah, it weighs 7 lbs.AND they only recommend 8 gauge for the installation of the 2500. well yeah.. like he said.. it does not use very much electricity at all...
August 29, 201213 yr 2000 watts RMS, 4 gauge input and ground, and one 80 amp fuse. Something doesn't add up. Oh yeah, it weighs 7 lbs.AND they only recommend 8 gauge for the installation of the 2500.I just seen that looking through the info online. Seems like the prices should be about cut in half as well as power ratings.
