Posted September 4, 201213 yr So I've decided that I don't like this 38-39hz tune at all. We have 9.5 cubes (after disp)current port is a 12.5 sonotube @14.5" longI can maybe stretch it 17" maybe, but all that extra port will be external. But that's only 36-37hz12" doesn't help much either...If I can find a 11.5" sonotube I can get to 34hz @17" long12.5"=122.6sqin of port=12.9sqin per cube11.5"=103.8sqin of port=10.9sqin per cubeMost people's rule of thumb for round to slot port is 3-4" so 12.9sqin per cube =15-16.9sqin per cube10.9=13-14.9So what do you ladies think? Edited September 4, 201213 yr by armykyle1
September 4, 201213 yr Dont see why it wouldnt work, try it out! Worst thing that will happen is that you still dont like how it sounds and need to try again?
September 4, 201213 yr Port area per cube is a joke (most of the time). You must calculate minimum port area per the driver(s) used and the desired tuning. Internal area doesn't matter either.
September 4, 201213 yr Yes^^. There is no realtion between enclosure volume and vent area. Power and driver displacement are the dominant factors. You need to model to find out what the vent velocity will be.
September 4, 201213 yr What drivers, amp, and "wiring down to?"I'd pick some tuning point, and calculate the vent mach for xxx port area. If vent mach is too high at xxx port area, and you can't increase port area due to port length constraints, then consider upping the tuning point until you find a happy medium. Edited September 4, 201213 yr by stefanhinote
September 5, 201213 yr Author They're custom ufo BTL 18's with Zv3 sofparts. D1'sseries/parallel to 1ohm. They'll be on a single DC5k for a short time then two DC5k's strapped @1ohm. I've tried modeling the subs but keep getting errors.The only TSP's I have are(series)SPL- 92.391w/1mR(e)- 1.834 Fs- 34.99Q(ts)- .41Q(es)- .44L(e)- 3.171M(ms)- 306.1gV(as)- 4.071cuftI would put xmax in the 28-30 ranger since stock is 28mm but these coils are slightly longer.
September 5, 201213 yr I came up with:For two of those drivers with 6kw with 35hz tuning:100in^2 vent mach 48.275 m/s / 0.14130in^2 vent mach 37.135 m/s / 0.108150in^2 vent mach 32.183 m/s / 0.093180in^2 vent mach 26.82 m/s / 0.078200in^2 vent mach 24.138 m/s / 0.07215in^2 vent mach 22.454 m/s / 0.065 Edited September 5, 201213 yr by stefanhinote
September 5, 201213 yr Author I came up with:For two of those drivers with 6kw with 35hz tuning:100in^2 vent mach 48.275 m/s / 0.14130in^2 vent mach 37.135 m/s / 0.108150in^2 vent mach 32.183 m/s / 0.093180in^2 vent mach 26.82 m/s / 0.078200in^2 vent mach 24.138 m/s / 0.07215in^2 vent mach 22.454 m/s / 0.065Which program are you using?
September 5, 201213 yr I came up with:For two of those drivers with 6kw with 35hz tuning:100in^2 vent mach 48.275 m/s / 0.14130in^2 vent mach 37.135 m/s / 0.108150in^2 vent mach 32.183 m/s / 0.093180in^2 vent mach 26.82 m/s / 0.078200in^2 vent mach 24.138 m/s / 0.07215in^2 vent mach 22.454 m/s / 0.065Which program are you using?http://portsgalore.s...om/?do=ventmachThe aero port section doesn't account for any flaring, just circular port area.You can try it along with winisd. Edited September 5, 201213 yr by stefanhinote
September 5, 201213 yr Also note that vas is in liters, not cubic feet, so you'll have to convert that.
September 5, 201213 yr Author Also note that vas is in liters, not cubic feet, so you'll have to convert that.Thank you. I didn't even look at that at first.
September 5, 201213 yr Author Looks like I'm going to give an 11" port a shot with the step down in power. Plus I'm thinking about getting some of those sa/oa 18's built. Need lows
September 5, 201213 yr Looks like I'm going to give an 11" port a shot with the step down in power. Plus I'm thinking about getting some of those sa/oa 18's built. Need lows You're going to switch from what you have to Sa's? Sounds like a bit of a downgrade.
September 5, 201213 yr Author Just saw your post about the shifted motor It shifted on the basket. Noob mistake. Used washers for spacer and loctite on only one screw.... Drinking and sub building lol. I already paid for parts to rebuild it. The SA/OA 18's should offer better low end and might perform better on the DC5k. I might have Nick use SPL coils, not sure yet. But I want then low lows
