September 15, 201213 yr Author nice build.... Looks like you pay attention to detail.Well the parts that are not carpeted cannot be seen with the final bits, But yea This is my first time doing anything with wood like this along with carpeting...so I'm satisfied with it
September 16, 201213 yr What about the tweets on thethe dash?and under the hood like the big 3 buddy? Edited September 16, 201213 yr by Dictator
September 16, 201213 yr Author What about the tweets on thethe dash?and under the hood like the big 3 buddy? ALL those coming soon going to post those today i suppose. XD. Im actually stull working on the tweets but ill show you them regaurdless, had to do some custom fitting. Also im getting some noise from the tweets, Ive checked the grounds, ive checked the rca's they are running seperate the power wire....I have no idea any suggestions? Edited September 16, 201213 yr by spare69
September 17, 201213 yr Author RCA'S ran behind the glove box area, I looked for DAYS for a spot to run wires behind here without taking off the dash completely...Turn around View of ItTweets in Dash, Not done its got some bad look to it from the cutout but will fix with some small wood pieces and tan vinyl.My typical Voltage at idle with no sound...4 amps hooked up with stock alternator....Also Red button to turn off my underglow lights separate the interior lights.My wire Mess with an infinity 4 channel amp powering the 2 front door speakers....Also battery........Will be cleaning these wires up a bit more....My alternator with Big 3My main Ground Wire under the Rear side Drivers seatWires from FirewallMy quick way of wiring the underglow..... Will be putting some rubber gromets and what not....ATM only have 1 side of lights because I failed to solder the other strips....(soldering guns are damm hot and burn your fingernail to your skin btw) found that out......Temporary For underglow until I get grommets...
September 17, 201213 yr Install in the rear looks real good man.We need to talk about your tweeters and headunit mounting in the front though.
September 17, 201213 yr Author Install in the rear looks real good man.We need to talk about your tweeters and headunit mounting in the front though.whats your thoughts? Im open to any suggestions! The original tweeters were smaller, so i dremilled them out a bit and have them in now, but in the process nicked it up a bit. I was thinking to wrap it in tan vinyl but idk.....
September 18, 201213 yr Author Hmmm Im thinking ill throw in a surprise twist and add another Fi BL 12" to the equation. Gimme 2 weeks.... XD
September 18, 201213 yr Nice install...seems like you know what your doing like others said could use a lil more work in certain areas... but its def a good start!
September 18, 201213 yr Author Take a razor blade to those corners How do you like the sound and output?I think the Edges of the carpet are just shot at a wierd angle there are no fuzzies hanging off the box or anything XD And it sounds kick-ass. See i listen mostly to rock and it has an awesome punch and very clear. Rap and Dubstep are great too. The box is designed for 2.5 Cubes ad thats what the sub needs. I have it wired at 0.5 Ohm. XD
September 18, 201213 yr Author Awesome Truck Sir !!! I'm digging the LIGHTS !!!Thanks man I'm actually not done yet, ive got to get smoeone to solder for me since i cant help but to burn myslef with it.... Ganna put some lights in the wheel wells of the car too.
September 18, 201213 yr Take a razor blade to those corners How do you like the sound and output?I think the Edges of the carpet are just shot at a wierd angle there are no fuzzies hanging off the box or anything XD And it sounds kick-ass. See i listen mostly to rock and it has an awesome punch and very clear. Rap and Dubstep are great too. The box is designed for 2.5 Cubes ad thats what the sub needs. I have it wired at 0.5 Ohm. XDYea This is my friend And i think he could hit 142 DB np.! Edited September 18, 201213 yr by Dictator
September 19, 201212 yr Awesome Truck Sir !!! I'm digging the LIGHTS !!!Thanks man I'm actually not done yet, ive got to get smoeone to solder for me since i cant help but to burn myslef with it.... Ganna put some lights in the wheel wells of the car too.We installed my LEDs around the hubs (Hub Glow Kits) ... worked great ...Just got to give plenty of slack for suspension travel ...
September 19, 201212 yr Author yea that looks tight bro, but ive got planned to just put them in the wells not the rims because thats tooo hard for me. lol Call me lazy, i just dont want to spend any money from what i can just use that i already have. But foreal man thats some kick-ass shit dude.
September 19, 201212 yr yea that looks tight bro, but ive got planned to just put them in the wells not the rims because thats tooo hard for me. lol Call me lazy, i just dont want to spend any money from what i can just use that i already have. But foreal man thats some kick-ass shit dude.Thank you Sir ... I understand, I'm on a tight budget with my ride too.Best of luck with it and please keep us posted with updates !!!
September 19, 201212 yr Alright so I spent a few hours doing random things to try to stop this interference grounding noise from the tweets, Added a few grounds to make my voltage stiffer, and now ive finally figured out that it was my RCA's so im having to rerun them....
September 21, 201212 yr Author So Ive tried EVERYTHING to get rid of this engine noise in the tweeters... New RCA's, new Grounds, Away from Power Wire, EVERYTHING!!! Can you all give me any ideas of what it might be?? Otherwise i might have to get one of those noise cancelling thingies... Im starting to think its the Amp Edited September 21, 201212 yr by spare69
September 21, 201212 yr is the amp gain all the way down on the amp that feeds the tweeters ?? does the amp feed the tweeters alone ??
September 21, 201212 yr Get a video of that mean looking machine I agree !!! Is that considered a UFO kit like mine ??
