Posted September 22, 201214 yr Hey just wondering what you guys would set your subsonic and lowpass filters to. I listen to all types of music and would just like to get some more output on songs other than rap.Just wondering where i should go i think i am at like 80 on low pass and 35 on subsonic.Thanks
September 22, 201214 yr Author It is in a 1.3 slot port 32hz box right now. I have a stock nav hu in a trailblazer. I am looking to just get bass out of all songs i feel like it is not hitting as much on rock type songs.
September 22, 201214 yr You could bring your subsonic down to like 25-27 and be fine. My box is 7 cubes tuned to 31hz for the xcon 18 and my lowpass is at like 70-80 and subsonic is mid 20's
September 22, 201214 yr It is in a 1.3 slot port 32hz box right now. I have a stock nav hu in a trailblazer. I am looking to just get bass out of all songs i feel like it is not hitting as much on rock type songs.I would lower the SSF to 28hz, and raise your LP to 100-125.
September 22, 201214 yr Usually 2-3 hz under you box tuning and you may need to readjust after your sub loosens up. Edited September 22, 201214 yr by nem
September 22, 201214 yr Author alright i will give it a shot and lower the sf and ill put lp to like 100 and see what i get.thanks guys.
September 22, 201214 yr alright i will give it a shot and lower the sf and ill put lp to like 100 and see what i get.thanks guys.Be careful setting the LPF too high, that is a big thing that can kill your sub (high power with very little excursion means the sub can't cool itself that well. Throw in the slightest bit of clipping and your sub will heat up extremely fast)
September 22, 201214 yr 100hz lowpass is perfectly fine. No it's not moving as far but it's also moving significantly faster.Set the SSF somewhere around ~25hz, set the lowpass to where ever you think it sounds best.
