Posted September 28, 201214 yr My question is can i use 14g wire to make My subs 2ohm?Then run 12g wire from the Sub to the amp?
September 28, 201214 yr My question is can i use 14g wire to make My subs 2ohm?Then run 12g wire from the Sub to the amp?Sure you can run 14 to the amp and subs.
September 28, 201214 yr Just my thoughts really depending on the subs i guess use 8guage wire from sub to amp. Just use all 8 guage its fairly cheap. Good luck did you decide on your set up yet bro?
September 28, 201214 yr Just my thoughts really depending on the subs i guess use 8guage wire from sub to amp. Just use all 8 guage its fairly cheap. Good luck did you decide on your set up yet bro?Why do you need 8 gauge?
September 28, 201214 yr Author I have 12 gauge.but i couldnt Get it all to fit.i have 2 sa 12s.i used the 14g to wire the.coils,then ran the 12g to the amp.I just makin sure i could do that with tearin sumthing up.
September 28, 201214 yr I have 12 gauge.but i couldnt Get it all to fit.i have 2 sa 12s.i used the 14g to wire the.coils,then ran the 12g to the amp.I just makin sure i could do that with tearin sumthing up.That is fine then to run 14 to 12 gauge.
