October 3, 201213 yr Quent is amazing help isnt he? You are a good dude quent and very knowledgeable. Thanks for the help once again that you gave me!Not a problem.
October 3, 201213 yr Author Quent is amazing help isnt he? You are a good dude quent and very knowledgeable. Thanks for the help once again that you gave me!Not a problem.thank you for your help
October 3, 201213 yr Author Is it possible to get the box a bit bigger and have it tuned to 32hz? That is what skar audio recommends maybe build the box to be 2.25 cut ft?
October 3, 201213 yr Author I hope is not much to ask by what I have asked if its needed can you design the box to be 2.25 cu ft tuned to 32hz plz so it can be. .75 cu ft per sub. Is that ok to do I like to hit the lows and well I would like to go with the manufactures specs. Thanks or atleast get. .7 cu ft per sub making the box to be 2.1cu ft tuned to 32hz Edited October 3, 201213 yr by oakteg21
October 3, 201213 yr I'd contact Kevin S. I don't even want to understand the thought process behind manufacture's specs. I do however have a firm grasp on enclosure design and cabin gain. And if those sub's were in my car I'd rather the the 1db gain from 34-50 hertz with an f3 of 29hz versus a loss of 1db gain in the playable range and a f3 of 27hz. Which you will more than likely have your subsonic filter set no lower than 30 hertz anyhow.
October 3, 201213 yr Author I'd contact Kevin S. I don't even want to understand the thought process behind manufacture's specs. I do however have a firm grasp on enclosure design and cabin gain. And if those sub's were in my car I'd rather the the 1db gain from 34-50 hertz with an f3 of 29hz versus a loss of 1db gain in the playable range and a f3 of 27hz. Which you will more than likely have your subsonic filter set no lower than 30 hertz anyhow.Ok so dumbing it down lol in other words you believe the subs will perform better in this enclosure then the manufactures recommended? Edited October 3, 201213 yr by oakteg21
October 3, 201213 yr Author In laymans terms it will give you better output o over a broader range.Alright awesome thanks for your help I really appreciate all you have done for me
October 4, 201213 yr Author Will this box let the subs hit the lows? I like them to hit the lows good.
January 10, 201313 yr just roll that box oakteg21. Quentin has built way more boxes then i have so i trust his design.
January 10, 201313 yr double check my shit. been awhile since i booted up autocad... also my design probably could be better, more 45s in the port to reduce turbulence, etc.
January 10, 201313 yr Author just roll that box oakteg21. Quentin has built way more boxes then i have so i trust his design.Yea I want to build it but don't know the cut sheet for it
January 10, 201313 yr Is it possible to get the box a bit bigger and have it tuned to 32hz? That is what skar audio recommends maybe build the box to be 2.25 cut ft?In laymans terms it will give you better output o over a broader range.errr, in laymans terms Kevin is a moron so ignore his recommendations. He can't explain any of them anyways as the t/s are wrong and he pulled them out of a hat. I am confident in Quentin's design enough that I would recommend it even though I haven't even looked at the driver specs or double checked anything. Roll with it!
January 10, 201313 yr Author I do want to roll with it but the thing with me is I don't know what size to cut the port walls
