Posted October 1, 201213 yr Well i'm looking at three different brand and would greatly appreciate everyones input on what yall think. Also i plan on running 3 of them in a 95 cadillac deville and i'm wanting 12 first i'm looking at- FI BL with hyper pole and cooling running dual 1ohmsecond- PSI platform 2 dual 1ohmthird- ssa icon dual 1ohmOnce again thank you for all imput
October 1, 201213 yr Running 3 subs can get tricky with impedance and amplifiers. What amplifiers do you have/plan to get? AND what are you looking to accomplish?More sound quality or higher spl? How much room do you have for the enclosure? It is so much simpler to run 2 12"s in the trunk facing rear than try and squeeze 3 in there, but then again I'm jumping the gun, please answer my previous questions.
October 1, 201213 yr Author I was looking at running the Crescendo Audio BC3500D, with a Mechman 250amp alternator and Kinetik KHC1400 up front and i didn't know if i needed one or two for the back but just in case i needed two more in the back i was going to run Kinetik KHC2000 and i'm going for more sound quality, and i have a lot of room for the enclosure i talked to Dustin from Dc creations about the enclosure and he said it would work perfectly.
October 1, 201213 yr I was looking at running the Crescendo Audio BC3500D, with a Mechman 250amp alternator and Kinetik KHC1400 up front and i didn't know if i needed one or two for the back but just in case i needed two more in the back i was going to run Kinetik KHC2000 and i'm going for more sound quality, and i have a lot of room for the enclosure i talked to Dustin from Dc creations about the enclosure and he said it would work perfectly.If SQ is the goal, I vote for the Icon.
October 3, 201213 yr Xcons are like orgasms on my ears...somedays i wish i had both xcons and zcons only have the z'sss love them both so much.
