Posted October 5, 201214 yr So i am not to familiar with many brands so i would like a few options out there on some amps. What i am looking for is something that is cea rated at 13.8v. I don't need that much power i need 500watts either at 1ohm or 4ohm rated. What i am powering is a single sundown 10" e-series. Reason i need a amp rated at 13.8 is because its going in a 2012 corolla and toyota seems to regulate at a lower voltage which is around 13.8.
October 5, 201214 yr Your ear will not be able to detect the difference between 13.8 and 14.4 volt electrical output. Not a ton of 500 watt amps are stable at 1 ohm, and an amp that does 500 watts at 4 ohms is probably going to be a lot bigger than you need. Go to Sonic Electronix and check out Kicker and Rockford Fosgate Punch (not Prime) amps. What is your budget?
October 5, 201214 yr i would find a old jl 500/1and thats ALOT of amp for that sub IMO. you could very easily use a jl 250/1both would give you your power at 4 ohms and they have a regulated power supply
October 5, 201213 yr Also a great choice is a Alpine PDX-M6, they do 600x1 at 4 ohms or 2 ohms. Really nice amps and are very small.
October 5, 201213 yr Don't focus on CEA ratings.You've just received 2 good advices !!! JL orAlpine ? It's up to you. It would be way cheaper toget one of those amps used. I think you can find great deals on some JL. Easily.Good luck. Without any info about your budget, hard to tell you more.
October 5, 201213 yr Will open up your options a lot if you look for a 2-channel amp & bridge it, although it will limit future upgrades some. Many of them are also class D so efficiency will be pretty similar to any mono amp.PPI 600.2 comes to mind. Sonicelectronix has them for $160 shipped.JBL also has some good options in the GTO lineup. Believe they have a GTO7001(?) that does around 425w @ 4ohm but also 700w @ 2ohm for future upgrade possibilities.
