Are they ok to use as a primary and secondary??? I can get a great deal on 2 blue top Optima Battery's. I want to use one under the hood (for the truck), and a second one inside (for the system).
Yep, marine applications really are similar as some of those trolling motors can really suck down the juice. If you are gettin' a good deal go for it, any marine store should have the conversion for the battery terminals even though I like the marine ones better.
Whats the difference?? Is it the threads or the diamiter (sp?) of the bolt??
They don't have regular posts, instead, they have a bolt/nut arrangement.
most blue's have regular (olde style) top mount terminals with the wing nut terminals attached. ult-9006-006_w.jpg
so as long as you can use top mount, u'll need the side post to top mount adapters, u'll be fine...
and liek everyone has stated..
DO IT!!!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
