Posted October 19, 201212 yr How long do you guys recommend breaking in the ssd's b4 going to competition with them and putting a lot of power on them?
October 19, 201212 yr None. There is no breakin period. Also ssd subs are more sq then spl.What do you consider alot of power? Edited October 19, 201212 yr by pmureika
October 19, 201212 yr None really, may peak alittle lower over time once they loosen up but the sub was tested before it was sent to you.
October 19, 201212 yr None. There is no breakin period. Also ssd subs are more sq then spl.What do you consider alot of power?There is nothing SQ about a SSD, its a good daily sub that will sound good in the right install. You will never see a SSD in a SQ car, but you will see them in SPL comps
October 19, 201212 yr None. There is no breakin period. Also ssd subs are more sq then spl.What do you consider alot of power?There is nothing SQ about a SSD, its a good daily sub that will sound good in the right install. You will never see a SSD in a SQ car, but you will see them in SPL compsI had a pair of 15 ssd d4's I though they told me they were sq subs. Sorry for the wrong info.
October 19, 201212 yr I still say they are more a daily driver than spl.I was referring to Scott's post about break in.
October 19, 201212 yr I still say they are more a daily driver than spl.I was referring to Scott's post about break in.Ok Quentin.
October 19, 201212 yr Author I've seen them in plenty of daily drivers and in spl lanes. Alot of power is only around 4000. That's not daily mind you just for a quick burp.
