Posted October 24, 201212 yr I've decided for my four door tahoe z71 2004 on going with a Pioneer AVH 4400, Was going to do the app radio but it only has 2 preouts. Along with that i am going to be getting a crescendo 5800bc amp, a total of four FI Bl series Subs (either 12 or 15 inches) with the cooling option, not sure on 1ohm or two ohm impedance. Along with that i will be building my own ported box tuned to 35 or 30 hz. For the tweeters i am just going to be running two crescendo ft1 and four pwx 6.5. Haven't chosen the amp on those. I do know i will need to upgrade my electrical system on my car. I'm just posting this for some feed back on what i could enhance or if 15 inch subs would be better than the 12 inch subs. on that not i want musical not comp, im not going to be doing any burps or anything, and also i mostly listen to electronic music and rap, but still would like to jam some country from time to time.
October 24, 201212 yr There are a couple different ways you can go about this. You will need a Active capable head unit (I didnt look the specs on yours).You will either need a small 2 channel amp for the tweeters 50w or 75w x 2 will be plenty. Then a 4 channel amp for the mids. 100w x 4 will be good on that one. Or you could run one bigger 4 channel and run the tweeters off 2 channels and the mids off the other like I am. I have a 150 x 4 and have the amp turned way down on my tweeters and then running mostly rms to my mids on the other 2 channels.Obviously 4 15's is alot more cone area than 4 12's. It will also require much more space for the enclosure. Your choice. This is a very large setup you are attempting and will cost a lot of money to run properly.My setup is somewhat similar and I have 4 XS D3400 batteries and also a 380amp alt and I could still use more battery.I hope you have 5, 6 or 7k to spend and also do all the work yourself. lolWelcome Edited October 24, 201212 yr by swift
October 24, 201212 yr Author thank you, and yes im about to sell my old tahoe but i didnt want to exceed 4000
