Posted November 16, 201212 yr Hi, I would like to know which is the best recommended Sound Quality sub available to buy in the SSA store, prefered size 12", i would love 15" but only have a maximum of a 4cu feet for the enclosure, Thanks.
November 16, 201212 yr What are the max dimensions you have available for a box? Sealed or ported? Price range? What are you going to power it with?
November 16, 201212 yr Need to know budget and better definition of your goals. My idea of sound quality and yours can be very different. Music selection and details of the rest of the system can be helpful as well.
November 16, 201212 yr Author I Did the big 3 and have extra batteries, Power is not a problem because i will purchase the amp depending on the Subs i purchase, Price range not really a problem, box max is 38w x 17h x 16d .
November 16, 201212 yr I Did the big 3 and have extra batteries, Power is not a problem because i will purchase the amp depending on the Subs i purchase, Price range not really a problem, box max is 38w x 17h x 16d .Most likely not necessary for an SQ sub. Nor is much power. The trick is going to not be the sub, but the front stage. There is a reason in the T&C for the site that you signed up to agree to not use the term SQ...
