First of all, hello to everyone.
I would build a box load Kerfed port tuned to 35hz for two sundown audio sa 8 "v.2 to be used as sub home who can help me?
Thanks to all and sorry for my not perfect English.
Greetings from Italy.
Welcome to SSA! Do you already have the subs? Why would you choose those subs for a home audio setup?
Thanks for the welcome
First of all, thanks for the reply.
I'll tell you I already have two Sundown SA-8 'v2 and I wanted to get a small sub to put under my desk PC.
The components of them would work at 8 ohms and piloterei them with a form hypex ucd 700 with a subwoofer velodyne sms 1 managemet system which of course I already have.
Welcome.
You have a Hypex 700? And you are going to use that to power 2 sa-8s? Then use it for a pc?
That just seems odd to run a $4000 amp for what you are doing.
Either way, if you want someone to help design an enclosure you will need to post what dimensions you have to work with.
Yeah post the dimensions and we can go from there.
Thanks for the help so I modules hypex I took them directly in the Netherlands and I spent a lot less than $ 4000 because I have spent a total of € 700 + processors approx $ 900.
The dimensions of the unit are 75 cm wide, 38 cm deep, 25 cm high.
The put also in inches width 29.55, 17.97 depth, height 9.85.
Thanks for helping a cordial greeting to all of you from Italy.
Do you plan to use the system strictly for music? Or will you be using it for movies as well?
My intention is to use mainly with music
