Posted December 4, 201212 yr Hi all ,I´d like to know if it matters at what voltage an amplifier makes their wattage ..is it more difficult to make an amplifier that has an higher voltage output , say 100Volts vs. 200Volts to keep amperage lower ,and why ?are the coils of drivers calulated to take a certain ratio of watts and amps ?do amplifiers of different brands but but same output have about the same voltage and amp output or are there big differences ?writing this I realize these questions sound pretty nooby , but I´ve never heard anybody talk about this ,while I´d think that it would matter , or at least on the high power amplifiers .... or are the amperages still so low it just doesn´t matter ?thanks . Edited December 4, 201212 yr by BASSmaster
December 4, 201212 yr You need to google ohms law first. Then the definition of efficiency. It may answer some of that question.
December 4, 201212 yr Author damn .. i think I´m just tyred ...the word `impedance just didn´t cross my mind` ...
December 10, 201212 yr i=currentv=voltager=resistancehigher the voltage the more amps received. I=V/Rlower the voltage more amps needed I=V/RYou can figure the rest out right?higher resistance , lower resistance ect ectV=I*R
