Posted December 26, 201212 yr I have an 07 Dodge Ram 3500 Mega CabMy head unit is:- Kenwood KDC-BT852HD. Which is 50W x 4In my front doors I have:- Alpine Type R SPR-69 speakers. Which is RMS 100w & Peak 300wIn the rear doors I have:- Alpine Type R SPR-60 which is RMS 100w & Peak 300wFor my sub I have:- Alpine Type R SWR-12D2 which is RMS 1000w and Peak 3000wNow I need help on choosing an amp to power everything and I`d like toget the most out of all 4 speakers and sub. I have a list below of amps that will work with my system.Which two amps would be best for my set up?Thanks!Sub amps:- Nakamichi - PA-1500 1200 Watt RMS Mono Digital Bass 1 Ohm Amplifier- TXA-1000D - Cadence Class D Mono Power 1000 Watt Amplifier- Q1-1200D Amplifier- Rockford Fosgate T1000-1bdCP (t10001bdcp) (2010 Model) 1000W RMS- Polk PA D1000.1- Power Acoustik - 2000W Class D Mono Amplifier with Bridging SynchronizationSpeaker amps:- Cadence Acoustics ZRS C9 600 Watt Peak 16V 4-Channel Class AB Amplifier- Alpine MRX-F65 4-Channel 640W RMS Amplifier- Rockford Fosgate T400-4 Power Series Compact 4-Channel Amplifier- Audioque AQ 120.4- JVC - 1000W Class AB Bridgeable Multichannel MOSFET Amplifier with Bass Boost Control- Pioneer - 800W Class D Bridgeable Multichannel Amplifier with Variable Low-Pass Filter
January 4, 201312 yr I didn't see any other thread, so I'll just reply here lol. What is your budget? And if quality is of any concern, you'll stay far far away from the Cadence TXA amps and JVC.
January 4, 201312 yr no need to amp the rear speakers. i'm not sticking your list, that's ridiculous. http://www.sonicelectronix.com/cat_m94_i26_boston-acoustics-2-channel-amplifiers.html2200 on the sub and either a 2200 or 2150 on the front speakers. personally i'd sell the front speakers and buy a set of comps.
February 4, 201312 yr Audioque 120.4 and Audioque 1200D. May as well match them up. Edited February 4, 201312 yr by R3dt34rz
February 12, 201312 yr Budget amp power acoustik bamf 4000 on eBay And a mb quart onyx 4x80 from sonic
February 13, 201312 yr Interesting answers on this thread. The RF Power amps are a step above the others you listed, if you can afford to get them that's the way I'd go for sure!
February 13, 201312 yr Sub amp-Nak or Rockford-I,ve used both and they are great.A cut above the others you mentioned. Speaker amp-Cadence or Rockford.I,ve used the Rockford and it sounds clean and is somewhat underated power wise.I haven't used the Cadence but I have seen good reviews on the ZRS series and I like it because you can bandpass the rear speakers to keep some of the high end out so they don't pull the stage backwards as bad.
