Finished off the sub box today and put it in my Jeep.
Over the next few weeks I'm gonna test and see how subs back/port back, subs up/port up, and subs forward/port forward sound
So far its looking like subs back/port back wont work due to my lack of sound deader/massive rattles.
  • 2 weeks later...
  • Replies 114
  • Views 12.5k
  • Good to hear, I'm definitely leaning toward Singer when I decide to go big.
Edited by BrutalBasser
I have a box with Subs up, Port back but I'm playing with different positions/setups to see what sounds best in my application.  Rather then going with everyone else and assuming subs up, port back will sound best just because I have an SUV.
This enclosure is tuned to about 30 Hz, and my Enclosure with subs up port back is tuned to about 32Hz if I remember correctly I'm too lazy to go find the thread with the design right now.
So far I've concluded for me without any deader on my vehicle Subs back/Port back just gives my rear hatch a beating and creates a ton of unwanted noise.
Audibly to the ears I don't notice much of a difference between subs up/port back compared to subs up/port up.  I don't have access to a meter to find the differences as far as Numbers go.
My current enclosure with subs/port up is close to the ceiling of my Jeep as you can see in the video though and I'm wondering how much that affects it.  I might take on 1 more attempt at a box with subs/port up but have it level'd off with my rear windshield rather then blocking it.
Yeah I'm very happy with the sound they produce.  Now I just need to work on my front stage before I add two more to my setup.
I think the jest of it is that subs up port back the air from the ports bounce off the hatch and push the waves from the subs forward.
And yea sub and port back will send them both to the rear with a little bounce from the hatch.
Best bet would probably be to face them forward kinda like a wall except its not sealed off.
all just theory tho
all just theory tho
Yeah Once I buy some straps I'll do it this way.  The straps I was using are currently in use by my father and without them the box slides a bit.
I built the box so I could try all 3 ways.
Edited by DanP
all just theory tho
Finally bought some straps and tested it this way so far I've only tried it with my rear seats folded down and it sounds pretty good, Tomorrow I'm gonna put up my back seats and see what effect that makes.
  • 2 weeks later...
The illuminating Hifonics text got annoying so I plasti dipped it
I love Plastidip haha.  I use it all the time.  That looks good on the Hifonics!
Edited by grayta
Well there's a local car audio competition tomorrow, Planned on going so I went to a car wash to get all the bird shit off my Jeep started overheating/leaking fluid in the car wash so I guess my plans changed.
Appears to be the lower radiator hose leaking, but wont know until the garage opens up on Monday.
Time to learn mechanics. Hopefully it is just a simple issue.
I'm gonna let a garage handle this, if it was any other issue then overheating I would tackle it myself, unless I was absolutely positive on the issue.
IMG_20130522_163701_zps777bf3ce.jpg?t=13
dayuummmm
the hell happened
ive seen small holes, but that its redic
dayuummmm
the hell happened
Drove into the car wash, left it idling for no more then 4 minutes, as I was getting in I heard a pop then saw steam flying.  When replacing it was seen that the connection for the fan was melted, but its hard to tell if the fan stopped working and caused the radiator to pop, or if the radiator popped and melted the fan connector.
  • 2 weeks later...
Got some work done today
The Router+Jasper jig makes life so much easier.
As I was finishing up UPS brought me tomorrows project,
Before
After:
I'm pretty happy with how it turned out, I just have to run a ground from front to back, then I can start cleaning up my cargo area.
The cabling looks much better.
You say the fuse melted on the fan?  Are you using an aftermarket electric fan in place of a mechanical?
Not the fuse the it was a little harness clip.
Is it aftermarket or stock?
I thought stock they used mech fans
Honestly I'm not sure since I didn't do the repairs myself I know all they did was hardwired the fan and it worked fine though.
