January 4, 201313 yr Author if my dimensions were D:27 L:47 H:33 what size would my aerports need to be to get it at around 30 hz or what is the math you do to get it
January 4, 201313 yr You would need some big aero ports to achieve the right amount of port area. Stick with the slot port.
January 4, 201313 yr Author alright what math do i need to do to get the right tunning ive always had someone design the box for me
January 4, 201313 yr another calculator says the port length should be 32, but ehh...You also have to factor in displacement for bracing and the sub, to be 98.7% accurate lolso right now ur looking at 16.622ft^3 of space, once we find the displacement we can adjust the port length to be more accurate.Which is going to be a smaller number which will make the port length longer and the port width smaller if the box volume gets too smalli think i looked at that right.http://www.the12volt.com/caraudio/boxcalcs.asp Edited January 4, 201313 yr by djjdnap
January 4, 201313 yr Isn't torres calc more accurate than re's calc?I read that else where but i was going for what i've used.RE's is convenient and then i just double check with http://www.the12volt.com/caraudio/boxcalcs.asp
January 4, 201313 yr Ohh gotcha. I use a few different things including the re to help get a picture in my head of what it'll look like. I used Torres for actually getting info.
January 4, 201313 yr Author thanks guys yall have been a ton of help i will start on build tommorow and upload a video of it when i get through it might take a couple of days
January 4, 201313 yr thanks guys yall have been a ton of help i will start on build tommorow and upload a video of it when i get through it might take a couple of daysSounds good!
January 4, 201313 yr Well lets try this again. lolhttp://www.hometheatershack.com/forums/enclosure-volume-calculator/#axzz2H2jRjm1bSo the volume was way off wt the RE calculator.But the cut out should be fine and the above is more accurate.It would really depend on ur displacement which i just put .5.......and now as i sit here looking at it my brain just went poofSomeone else feel free to jump in
January 4, 201313 yr so dont use the re calculator?It will work fine for the initial setup.The only thing is the port length and depth are not correct for the frequency you want.Which is what i was attempting to figure out above with the 8in width and 23 inch depth..But since your depth is 27 i would i would have an L port, so instead of straight 23" piece run it back like 13" and make have a perpendicular piece to that that is 10" =23 total
January 4, 201313 yr LOL i think this is the most work ive done in a while on here lolWell i just checked 3 cut sheets fi has on its page against the RE calculator and everything came out right.Soooo might as well use it. loli doubt 1hz off is going to be that big of a deal even if it is.So id just stick to the RE calculator for convenience, im no expert by any means.
January 4, 201313 yr Author thanks man i give you all the props in the world you have been alot of help so still do the L port and just go with the re dimensions correct?
January 5, 201313 yr nah just use the one from page 2 that i posted, or you can change things up urself if u goto the calculator to tweak it the way u want
January 7, 201313 yr Author i got the box built and the sub in and my amp was blown never been so bummed out in my life!
January 7, 201313 yr man that was some fast building.Sorry to hear about the amp.Its plenty of amps for sale on caraudio.com and smd.com, not to mention a few on here as well.
January 7, 201313 yr Author yeah pretty fast we started at 10 in the morning and finished around 9 and ill look around for some ill order tommorow evening when i get some money in the bank when it gets in ill put a video of the system going on here
January 7, 201313 yr Yea that really was some fast building. Sorry about the amp. I have a kicker zr1000 for sale. Does its max rms power at 2-4 ohms. So it'll be more efficient.
February 7, 201313 yr Author Yeah im pretty happy I just want something louder now im always like that never happy its the loudest system I've had but now im looking into selling it and getting a btl 18 with the ufo style magnet
